Farmall h starting problem again
Posted by Farmallboy15 on April 03, 2011 at 06:23:10 from (67.54.223.80):
Okay the starter was jammed in the flywheel. But it still wont start. I do think i screwed something up when i put on the tune up kit because i do not have spark. There is no ignition switch so thats not the problem, coil shouldnt be the problem. Im hoping its the timing. Currently i have the points set so there is a gap when the distributor hits a corner on the shaft. Is this right? Thanks
