Re: Re: Re: Re: Hey Red...CUB Engine Noise...Need Further Advice
Posted by george on July 29, 2000 at 09:50:13 from (172.162.211.224):
In Reply to: Re: Re: Re: Hey Red...CUB Engine Noise...Need Further Advice posted by The Red on July 29, 2000 at 09:33:26:
What about this...
That No.1 plug "looks different". Although all the plugs are new (not brand new) the No.1 is cleaner.
Is it possible that I'm chasing a mechanical problem when I have an ignition problem? The knock (although not what I would consider spark knock) does dissapear under full vaccuum. I pulled the distributor cap. Looks ok. There's a little green on the contacts from moisture.
Since I haven't seen anything obvious on the mechanical side, I'm thinking I'll put the pan back on, check the valve clearance, and check-out the ignition system. Maybe a bad wire on No.1 giving inconsistant spark?
I'd hate to run the thing with a mechanical problem and have it self-destruct, although it doesn't give me that impression...yet.
What do you think?
Post A Followup
: Re: Re: Re: Re: Re: Hey Red...CUB Engine Noise...Need Further Advice
