Re: 706 engines
Posted by CNKS on May 10, 2011 at 18:26:10 from (216.144.104.128):
In Reply to: Re: 706 engines posted by ih706user on May 10, 2011 at 11:23:30:
Current gas ratings are (Research method + Motor method)/2. I think when the 706 was built, IH used the research method, only, giving 93 octane as their recommendation. I have read that the current motor method must give an octane rating of 82--I have not confirmed this. But, if true, you solve for the current (R+M)/2 by:
(93+82)/2 = 87.5 -- or the current rating for todays regular gas, depending on where you live. Another way of doing it is using 87 as the (R+M)/2 rating along with the presumed 82 motor method, and solving for the Research number. That is 87=(R+82)/2. Solving for R gives an research octane rating of 92, also from the current 87 octane gas, very close to IH's rating.
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
