Re: Cub Fires on Exhaust Stroke
Posted by Jim Becker on June 01, 2011 at 12:07:53 from (173.57.144.251):
In Reply to: Cub Fires on Exhaust Stroke posted by rhtx55 on June 01, 2011 at 06:12:20:
If you had gotten real smart, you could have shined the light on the front pulley and watched for the TDC notch to line up with the pointer. If there are 2 notches, the first is advance, the second TDC.
The increased resistance turning the distributor is slight and also depends on have the points somewhere close to properly gapped. If you can't feel it, take the rotor and dust cover off and look for the cam coming in contact with the point rub block.
