Re: Corroded battery cable
Posted by agpilot on June 09, 2011 at 17:47:16 from (50.33.2.23):
In Reply to: Corroded battery cable posted by equeen on June 09, 2011 at 16:38:49:
Hi equeen: You should post a picture for all who have NOT seen bad cables up close. Makes a believer out of most who ignor cables and convert to 12 volts or electronic ignition thinking cables can't make that much difference in starting. ag
