Re: Touch Control on a C
Posted by achodges1 on June 20, 2011 at 11:06:59 from (66.141.170.151):
In Reply to: Touch Control on a C posted by Dave Cook on June 20, 2011 at 09:34:19:
When you said both sections moved were you talking about the lift arms or the control rods. If your control rod is not free you have no control to move the arm. If the right control does not move you need to determine if it is the lever that is stuck or the valve in the touch-control. Undo the rod that connects them and free up the part that is stuck. Then see what it does.
