If your hitch linkage is adjusted correctly the system will not go on high pressure when lever is full raise or lower. If you are getting 1400 psi by activating aux valve lever that sounds good for pump and relief valve, sooo I am thinking your fluid is by passing right at the hitch cylinder or the check valve of the hitch cylinder. You can easily check either or both. Just unhook hoses from check valve and hook directly into block check valve is bolted to and plug block outlets. To check cyl just unhook hose that is return while lifting. With some kind of a load on hitch, and hitch not moving no oil should come out.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
