Re: Farmall M Gears in front not turning
Posted by Bill in NJ on August 20, 2011 at 09:08:38 from (4.248.92.7):
In Reply to: Farmall M Gears in front not turning posted by John Lundberg on August 20, 2011 at 08:55:32:
If the engine front pulley is turning when you hit the starter, the crank is not broken. However the crank or cam gear could be broken, or stripped. Pull the timing cover off of the front of the engine and you should see the problem.
Today's Featured Article - History of the Nuffield Tractor: Conclusion - by Anthony West. In the last piece I mentioned that Nuffield had reached the stage where they had chosen to drop the "Universal" from production. The two new models were given three figure numbers, instead of "three" and "four". Model numbers were introduced to help farmers and dealers instantly recognize the engine size and horsepower of the tractor, the 4/60 had a four cylinder diesel engine which developed 60 bhp at 2,000 rpm. The 3/42 had a 3 cylinder diesel engine which produced 42 bhp at 2,000 rpm. Th ... [Read Article]
