Re: H starting problem
Posted by Janicholson on August 20, 2011 at 15:28:06 from (67.72.98.45):
In Reply to: H starting problem posted by Wyokid on August 20, 2011 at 15:22:20:
Getting gas to the carb is not the same as getting it to the air flowing in. Checking the float action, abd assuring it is filling the bowl is important.
If the condenser is bad in the Mag, it can also have this effect. Point gap is .013" on the high point of the breaker cam. Be sure to keep the rotor in time with the cam gear in the Mag.
Jim
