Splitting an 826 for a clutch have a few questions??
Posted by Jeff Gibson on March 13, 2012 at 19:17:20 from (166.249.96.90):
I am getting ready to split an 826 to replace the clutch and the ipto shaft,(no brakes pto steering etc) I am ready to split the tractor and want to run the plan past someone. First I plan to use a jack stand under each of the frame rails in the front the jack stands are rated for 6 tons each. I then plan to use a floor jack under the transmission and have it run in steel channel on the floor so it doesn't move when i am splitting the front and back. Does the thinner part of the bell housing remain attached to the engine and the frame rails on the front half to provide support for the back of the engine? I'm sure I will have more questions as I go.
Thanks,
Jeff
