Re: Re: Farmall M twelve volt conversion
Posted by ltf in nc on September 19, 2000 at 12:24:07 from (206.228.214.212):
In Reply to: Re: Farmall M twelve volt conversion posted by Ted(MD) on September 19, 2000 at 09:57:51:
You can wire a Ford type solenoid switch in line with the one wire going to the alternator. Just put the alternator leads after cutting to where the battery terminals would normally go on the solenoid and wire the control voltage to the solenoid (small side terminal) to the ignition switch terminal(hot with switch on) This will easily handle the current and the solenoids are cheap and plentiful plus it will work automatically
Post A Followup
: Re: Re: Re: Farmall M twelve volt conversion
