Holley jets can be installed. a drill press, a tap and a tool that grabs them jets n holds them tight so they dont fall inside the bowl when u install em. our old 706 with a 291 kit, we overhauled it, and was retuned on the dyno. I removed the elect solinoid, put in a manual adjustment screw from a M. jetted the main to .093. seemed to help with pump gas. them heads r choked thru the exhaust. Holds in alot of heat! cant exhale well! Opened em up a lil bit n dropped 10 degrees operating temp under a load. Had a 560 that had an eggshaped bore in the block when the sleeve was installed, it got tight. had to put in a repair sleeve to straighten it back out n she is still going. Now, if i can get brave enuff to put a new headgasket in dads 856d with a M&W turbo!
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
