Re: No start A Farmall
Posted by JRSutton on May 25, 2012 at 15:42:22 from (75.130.109.233):
In Reply to: Re: No start A Farmall posted by Gordoro on May 25, 2012 at 12:26:28:
Unlikely that it's an issue. Hard to build up vacuum at slow speed with the open carb sitting right there.
But you can try to feel for vacuum over the face of the carb's inlet. Might be more accurate at slow starter speed.
If there truly is no vacuum - you've got to look for a leak in the manifold connection.
It can happen, but I'm still thinking it's much more likely a problem with the carb. Either blocked internally - or flooding.
Does it drip gas at all? if so that hints at flooding.
However firing only with starting fluid hints that you've got gas blockage.
Personally I'd focos on that angle. Remove the carb and clean everything.
