Posted by DPittsley on May 28, 2012 at 09:37:21 from (74.71.34.165):
I have a Farmall 240 and am having problems with the hydraulic system. The rear draw bar / three point hitch does go up and down; however it cannot lift any weight. If I lift it with no weight on it then stand on it, it will NOT go down, not unless I bring it down with the lever. I've looked every where to find out how much hydraulic fluid to add without any luck. Also is there a way to check the levels of the fluid? Do I need to bleed the system? If so how? I've added two gallons of trans-hydraulic fluid to the rear end box but this didn't help.
This happened suddenly. One day it worked the next it didn't
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
