Farmall A erratic running
Posted by CoreyM on June 04, 2012 at 07:03:21 from (174.252.124.3):
I have a 47 A that has been in storage for several years, Im about to start tinkering with it again, however what lead to its storage was very erratic running. Every time the throttle is advanced the engine will sputter and back fire, even worse if the throttle is moved very fast. This all started one day when the tractor was put under a load, ever since I"ve not been able to get it to run correctly. The inginition system was throughley gon through, timing and points set, it"s almost like the engine is leaning out. Just looking for suggestions .
