Re: M carb float and needle valve problems
Posted by pete 23 on July 06, 2012 at 10:05:40 from (74.32.238.2):
In Reply to: M carb float and needle valve problems posted by Marty from MN on July 06, 2012 at 09:28:13:
There is no problem getting the hinge pin to stay
i place. If pin is too short just make a new one
out of a nail or other suitable pin. There should
be minimum clearance between float hanger and
float, just so it does not bind. Your float may be
hanging on the sides of the bowl causing your
problem also. I took an old carb years ago, cut
the bottom out for a gauge to set those floats.
You have to determine if it is touching sides.
Many different ways of doing that. Also, the
rubber tipped needles are the best as they were
released way back in the early 60's to overcome
problems with leaking needles due to larger fuel
tanks having more pressure on needle. You have to
make sure it absolutely seals. I tip carb upside
down and suck on inlet. It has to hold a vacuum on
your tongue indefinetely. I also peen the seats
as they are often poorly made. I use a inj nozzle
needle to do so but an old steel will work fine.
Get a good needle and seat from CASEIH as their
new ones seems to be good like they were years
ago.
