Posted by D Slater on August 27, 2012 at 13:43:07 from (184.15.7.159):
In Reply to: 450 tach cable posted by P and R Pete on August 27, 2012 at 13:26:59:
If the cable won't pull out you have a problem. Just slides in. Housing # 2 holds the drive gear for the tach cable. The two round head screws and retaining plate hold the tach drive housing in. Looks like you have the late type so there's no adjustment needed when putting back in if removed. If lucky the tach cable drive gear is not striped. Wouldn't bet on it though.
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and
... [Read Article]
Latest Ad:
[More Ads]
