Re: 450 tach cable
Posted by P and R Pete on August 27, 2012 at 13:58:51 from (173.86.60.179):
In Reply to: Re: 450 tach cable posted by D Slater on August 27, 2012 at 13:43:07:
Thanks.
If I take the two screws out and the retaining plate off, that threaded part will be removable from the larger housing?
If so, will I be able to see that drive gear?
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
