Re: Hot Coil?? is it bad.
Posted by NolanJae on September 05, 2012 at 06:58:54 from (156.98.127.101):
In Reply to: Re: Hot Coil?? is it bad. posted by John T on September 05, 2012 at 06:19:02:
Thanks for the info. I dont know much about electrical systems. I'm still leaning towards a carb issue but would a coil cause a rich running motor due to lack or low spark? I've gone through the carb several times- soak-blow-clean-adjust float each time and now im haveing to lean the main scew to one turn to keep from fouling plugs and blowing smoke. The motor was completely overhauled last winter.
