Re: Hot Coil?? is it bad.
Posted by John T on September 05, 2012 at 06:19:02 from (216.249.82.117):
In Reply to: Hot Coil?? is it bad. posted by NolanJae on September 05, 2012 at 05:59:40:
Anytime the key is left on and the points are closed but shes NOT running, the coil (and any ballast resistor) will get fairly warm. Also if theres resistive carbon (often the case) on the points that will cause them to get hot also.
The cap and rotor n plug wires etc even if off the tractor has nuttin to do with the fact that the coils LV primary circuit (points, ballast, coil primary) continues to draw current if the ign switch is on.
A short term heating of the coil likely didnt hurt anything but if the ign is left on a longgggggggg time while shes not running now that could harm the coil and points
John T
