Re: 1947 H light switch wiring
Posted by Frankenford on December 03, 2012 at 14:00:07 from (8.24.105.231):
In Reply to: Re: 1947 H light switch wiring posted by Bob M on December 03, 2012 at 12:25:34:
Hi Bob;
Well I've got a diagram that you had posted on YT here and it shows the headlights would go on the top terminal on the headlight resistor. It also shows where I should hook up the rear light to. It as well shows at the bottom of the diagram where I wish to refer to as a foil wrapped resistor that is labeled as the field resistor has me stumped. Do I need to put a wire on that terminal at all? Currently there is none? Other wise it appears that if I connect the headlights to the top terminal on the headlight resistor and the rear lights to the terminal I would say more in the center, it should be finished. But one more question is can I power the light switch so that the engine must be running to turn on the headlights? Other wise I have power to the headlight switch all the time and if left on could kill the battery. I have my grandson does alot of work with the tractor but he could easily forget to turn the switch off. The battery is brand new so if I trickle charge it to full charge the amp gauge should drop to barely charging if the regulator is in fact working right, is that correct?
