Re: MD Diesel Bleeding?
Posted by D Slater on December 17, 2012 at 17:19:12 from (184.15.46.232):
In Reply to: MD Diesel Bleeding? posted by hattrick on December 17, 2012 at 16:33:52:
If you have a pressure gage on the pump it should go to the run zone when running on gas. Fuel goes to the primary pump on the rear of main injection pump before it goes through the final filter. If you don't have a leak or blockage on the suction side of the primary pump and all the air out you should get pressure to the injection pump. Its gravity flow but you can double check for air at the final filter when running on gas.
This post was edited by D Slater at 18:30:26 12/17/12.
