Re: FARMALL 460 Stalling Issue
Posted by RJG on January 21, 2013 at 17:25:40 from (74.46.209.110):
In Reply to: FARMALL 460 Stalling Issue posted by CNKS on January 21, 2013 at 17:22:48:
Hi;
Yes...the main jet is set at 5 turns out. I was referring to the Idle mixture jet having a sweet spot.
Thanks.
