What Vet is say is to set the timing at 30 degrees advance with engine running at full throttle, about 1980 rpm, but at least 1800 rpm. Often referred to as high idle speed in service manuals. If dist is in good shape then the timing will be very close to top dead center at low idle speed of about 450 rpm.
Today's Featured Article - Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
