Back the timing back down and set it at max gov. RPM for full advance . Now with out going out to the truck and getting my books out i can not tell you off the top of my head to the exact total degrees it is set at. Next set the main fuel screw to 4 1/2 turns off the seat as a starting point . And like others have said make sure your heat riser is working . Even IF the flapper is working more then likely the area around the intake tube has carbon build up and it is not allowing the exhaust heat to warm the intake properly .
Today's Featured Article - Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
