Re: Super C Governor Problem
Posted by Janicholson on January 25, 2013 at 16:44:13 from (74.60.94.18):
In Reply to: Re: Super C Governor Problem posted by Bud W on January 25, 2013 at 16:28:01:
The weights must move the thrust bushing evenly and the same from both weights. The weights must be free on their pins, but not loose or wiggly. The ball thrust bearing must be smooth, and the races need to be smooth where they touch the rock shaft prongs. Can the output (to carb) linkage be moved by hand when the engine is running? Jim
