Re: Super C Governor Problem
Posted by Bud W on January 25, 2013 at 16:28:01 from (70.242.114.188):
In Reply to: Re: Super C Governor Problem posted by Janicholson on January 25, 2013 at 15:56:42:
All of the levers move as they should and with the tractor not running you can move the throttle and thus move the rod to the carb. Now with the tractor running its all stuck . The weights seem to pivit ok . What is the purpose of the thrust spring and pin? I used a magnet to try to get the pin to move out of the main shaft and it doen't want to move. Could this have anything to do with my problem??
