They WERE NOT USED on six volt systems , I H never changed coils when they went to twelve volt they added the resistor into the systems . when they went to the twleve they put the resistors next to the coild and like said above the BLACK wire hooks to it and there is a WHITE wire coming from the R post on the starter tha bypasses the resistor to give the coil a shot of straight 12 for a hot start when you press the starter button . Once you let off the starter button all the juice then goes thru the resistor and the 12 volt feed is cut down to 6-8 volts to the coil. to save the coil and the points. You can use either a GM resistor or one off a Mopar that has the two terminals They did not go to this till the 460-560 .
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
