Re: Tractor Repair
Posted by ken house on April 01, 2013 at 18:28:15 from (173.242.241.169):
In Reply to: Tractor Repair posted by Frank Castro on April 01, 2013 at 16:38:53:
run a wire from hot side of battery to battery side of coil. (hot wire)
this bypasses switch, etc.
it is obvious that if it starts, coil, points, plugs, distributor are all o k.
