Posted by EM Iowa on July 01, 2013 at 05:38:51 from (67.55.190.168):
We got the flywheel on the crank without the key, the key must have been holding us up. I used a file to take a little off the key, but even as we hammered it in, it stopped at about 1/2 inch to go, and we noticed a hairline crack in the flywheel besides the key......so I'll cut off the key and leave it where it is. There is no way that key is coming out btw, it's way too messed up.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
