Re: Thought I had the H fixed.
Posted by gene bender on July 10, 2013 at 17:08:26 from (67.55.227.12):
In Reply to: Thought I had the H fixed. posted by Shop teacher 94 on July 10, 2013 at 12:44:17:
You can adjust the mag all you want and it does not affect the timing when starting it fires on TDC T hen when ngine runs goes to 33 deg advance and you cannot change that. You have a bad coil or condenser and to change the condenser you need to remove the mag from the engine.
