Re: Loud left final drive gear or Transmission 130 Farmall 1958
Posted by gene bender on September 18, 2013 at 11:43:14 from (207.177.56.241):
In Reply to: Loud left final drive gear or Transmission 130 Farmall 1958 posted by William Catalina on September 18, 2013 at 11:29:46:
So much for your local expert. There is a level plug on the left side of the tranny and it doesent take that much for a fill. There is a plug in the final to fill them as they do not get anything from the tranny. To drain the finals remove the bottom pan then you can fill thru the plug with 90wt. Your bearings could be bad if the wheel will move in and out. You can remove the axle and check the bearings if you have side play or even in and out as there should not be any play either way. Splines could be worn on the axle where the bull gear fits also but you will not know untill it is taken apart./ When you have the pan off it can be checked easy but something is wrong according to your post. Those are good tractors and only being 60 pluss yrs old things do wear.
