Posted by sony224422 on January 27, 2014 at 09:14:42 from (12.111.44.98):
I cleaned my carb and checked my float and got it to stop leaking. I also replaced the spring in my governor. While in there I adjusted the carb to governor linkage that was pretty out of whack. I swapped engines from a bad one to a new one and the governor was swapped too. So the adjustments make sense. The adjustments made a big difference along with the carb cleaning but now my question is, when starting off in 5th gear it sounds like it's about to stall, but won't and will eventually pick up and go. Once going it seems ok until I start going up hill. It seems like it bogs down a lot and really works to try to keep going and I lose speed. I'm not sure how normal this is. The uphill is a slight incline but maybe 1/2 mile long. I also noticed sometimes it seems to surge while driving on flat ground but I can't predict when it will do it or if it will do it. Is this a governor issue or a carb issue? I think my carb is adjusted pretty well but I've also never heard a well running tractor. It seems to idle well, at a very slow speed and cleanly revs to full throttle with little black smoke. I also have electronic ignition.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w
... [Read Article]
Latest Ad:
[More Ads]
