Re: 1945 Farmall M Vapor Lock
Posted by charlie M on February 16, 2014 at 04:48:19 from (173.85.161.240):
In Reply to: Re: 1945 Farmall M Vapor Lock posted by blohr on February 16, 2014 at 02:10:06:
Lots of reasons your tractor won't start even though there is gas to the carb. Some that come to mind include: weak electrical system, flooded engine, vacuum leak between carb and intake valves, plugged jets in carb, something wrong with the choke, valve problems. Does your carb leak gas if you crank the tractor alot and it doesn't start? I'd start by pulling the plugs, see if they are wet and see if you have good spark on them. While you have them out see if you have good compression. You have to start eliminating potential problems to find out where the real problem is at.
