1949 Farmall M
Posted by mcgyver44 on February 25, 2014 at 19:10:37 from (63.64.36.17):
Was pushing snow here tonight with the Farmall M and very rapidly lost forward momentum. The tractor now sits blocking my driveway. Problem is that I can push in the clutch, put it in gear and nothing when I disengage. The hydraulics also quit working. I am not that savvy with tractor transmissions. The clutch feels solid the shifter moves fluidly. There was no smell prior or slipping of the clutch prior. It happened rather rapidly. Within about twenty feet I went from ops normal to nothing. The tractor is able to be moved in neutral freely with a truck and chain. Is there a shear pin? Is this a clutch issue? Any suggestions much appreciated.
