Re: M Hydraulic issue, low/no pressure
Posted by Raymond Trum-Searah on March 12, 2014 at 06:01:29 from (67.142.181.24):
In Reply to: M Hydraulic issue, low/no pressure posted by Rick Remmert on March 11, 2014 at 15:31:15:
When I said 500 I screwed up
Using a 10,000 psi gauge I can't see small amounts
But I would see 500 if it got that high, it never leaves 0psi
From the picture I posted you will see I don't have the line back to fill port on bottom
if I have an open house I will spray fluid out of the line, so I have flow. But I have no pressure what do ever
I was able to move the kicker on my new holland bailed, which has a 2 way cylinder. It took a couple minutes to move it 20 degrees right or left
any more info needed let me know
Could I maybe have a bad valve???
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
