Re: M Hydraulic issue, low/no pressure
Posted by D Slater on March 12, 2014 at 06:35:01 from (184.14.194.188):
In Reply to: Re: M Hydraulic issue, low/no pressure posted by Raymond Trum-Searah on March 12, 2014 at 06:01:29:
You have the regular IH type control valve that returns oil out the bottom of the valve back to the fill opening. They used a fill cap that the vent could be closed when using the remote valve on double acting cylinders.
Vent would have no effect on a pressure check though.
With nothing hooked to the remote lines. Remote lever moved and with little lock on the side locking the remote in place you get all the pressure available at a side opening when the liftall unit lever is moved to the rear.
If pressure is low with good oil level, dropping the pump to find the problem is the next step.
Since you have some oil movement the pump drive and pump must still be in the tractor.
