Re: Supera ignition problems
Posted by Janicholson on May 10, 2014 at 06:42:07 from (74.60.94.18):
In Reply to: Supera ignition problems posted by Charlie Seale on May 10, 2014 at 05:53:17:
Carbon tracking on inside of cap or on the rotor, cracks in the cap, moisture in the cap (WD40 is designed for this) Jim
