Are you sure you have the plug wires in the correct firing order on the cap and to the correct sparkplugs? Should be in this firing order: Hal
2-1 4-3 As the rotor rotates CW. With No1. plug near the radiator. Rub the points with some wet or dry 320. Is the battery fully charged? If the voltage drops too much during cranking you may not have enough voltage for your ignition. Try pull starting to see if will start. Hal
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
