Carter UT/ Farmall 200 no start stall
Posted by clint s on May 17, 2014 at 08:00:31 from (67.242.45.169):
What is the float setting on a carter UT on a 200 and more importantly how do you set it. Where do you take the measurements from. From the float from the tang. With the needle open or closed.
Having a problem with my 200. It will run good for a few days then sometimes it will stall and not start. Problem persisted after changing points and condenser. Cleaning and regapping plugs and changing to another coil which I believe is good (spark looked the same between the 2 coils. Plug wires are newer and ohmed out good. Ran a wire from positive battery to the positive coil to eliminate wiring being faulty. I also took the carb apart and clean it real good. Spark looks ok and it will not restart with a shot of either. Seems like alot of gas coming out the weep hole in bottom of carb when trying to restart so I want to try and set the float. Probably time to take a compression reading too. Problem seems to have come to ahead because before it would stall out, but with a little coaxing I could get it running, now it will not start at all.
Clint
