Re: IH 2400b with D179 starting problems
Posted by Dieseltech on May 30, 2014 at 07:35:41 from (98.206.80.148):
In Reply to: IH 2400b with D179 starting problems posted by Charlie Yancey on May 30, 2014 at 07:03:48:
Did you remove the pump timing plate cover to check the camplate scribe line, should align with the pointer at 14 BTDC on the crank pulley.
