Re: Stuck In Reverse
Posted by famousfather on July 06, 2014 at 15:39:40 from (75.133.49.203):
In Reply to: Re: Stuck In Reverse posted by old on July 06, 2014 at 14:16:40:
Old, Thanks for your quick response. Tried your T/A suggestion, but no go. Shifter feels like it's in neutral and will only move into 2nd or 3rd. Can't get shifter into reverse, 1st, 4th or 5th no matter where the T/A is placed. Trans is still stuck in reverse and tractor will still move in reverse but still stalls when shifter is moved into 2nd or 3rd gear and clutch is let out while trying to move forward. Thanks for your suggestion.
