Re: Stuck In Reverse
Posted by old on July 06, 2014 at 20:30:15 from (209.86.226.59):
In Reply to: Re: Stuck In Reverse posted by famousfather on July 06, 2014 at 15:39:40:
Sounds like it is time to pull the shifter and then by hand move the shift rail to neutral and go from there
