B414 Diesel Engine Troubleshooting Help needed..
Posted by T-Bonz on August 12, 2014 at 07:07:04 from (204.80.29.132):
Hello, I inherited my dad's old B414 Diesel.. The tractor has always smoked for the 30 years he owned it.. I may make some effort to get this running right if the smoke from behind it doesn't kill me first when trying to hook up 3 point equipment..
Here is the History.. Dad put a brand spanking new IH short block in the tractor 30 years ago and had a local backyard tractor mechanic install it and get it running.. It burns no oil at all and probably only has 400 hours of run time since new block.. The tractor runs and seems to have ok power but has always smoked..from idle through full throttle.. I was wondering if it could have an issue with the "pre-combustion" chamber inserts being plugged or possibly crappy injectors causing the issues? or maybe just the injection pump timing is off?? The engine has the normal diesel sound and these engines have like 22:1 compression ratio so they ping a little anyway I guess? Something has just never seemed quite right with it.. I see you can purchase 4 new injectors and pre-combustion chambers for around $300.. Any suggestions before they find me dead behind this stinky beast?? Thanks!
