Another idea is a loose coupler flange on the input to the trans from the clutch coupling "joint". It is splined, and if it were loose, the clutch shaft and coupler could move forward enough to disengage, stopping everything in the trans, including the PTO. It would require the removal of the belly pump/reservoir to access the input shaft assembly. If the clutch will allow you to operate the tractor in road gear with no slipping, I doubt the clutch is the issue. Jim
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
