Re: starter motor will not stop running
Posted by homebre973 on August 30, 2014 at 09:02:32 from (209.179.60.56):
In Reply to: starter motor will not stop running posted by old on August 29, 2014 at 13:47:30:
Back again. I replaced the solenoid, started right up, but wouldn't stop again until I took the battery off. I am recharging the battery now as someone mentioned, but I have the ignition switch out. I have a multitester. The ignition switch has 3 bolts around the periphery and a center bold.
1. In the off position (farthest counter clockwise): battery and ACC show continuity, but no other combinations.
2. Next position clockwise, nothing shows continuity.
3. Next position all three outer posts show continuity with each other, none show continuity with center post
4. Last position, center post shows continuity with ignition post.
This seems correct to me.
Any suggestions would help. Could it have been a weak battery? If so why? Appreciate the help.
