Farmall H Alternator Wiring
Posted by fixer2u on September 17, 2014 at 13:59:52 from (168.215.57.130):
third party image
OK all help me out here. I converted our 6V positive ground model H with generator to 12V negative ground. I wired it per the attached pic I found on this site. I have tried two known to work Delco 10SI three wire alternators, both with dummy light and or diode and it will still not charge.... I have checked and double checked all the wiring and made sure there are good connections. I have had others check the wiring to make sure I followed the path correctly and still I cannot get this guy to charge. WHat could be my issue?
