Re: 1456 Aternator, Voltage Regulator, Batteries ???
Posted by Janicholson on October 03, 2014 at 18:45:38 from (74.60.94.18):
In Reply to: 1456 Aternator, Voltage Regulator, Batteries ??? posted by Weldon K on October 03, 2014 at 15:32:20:
third party image
The original system used an external regulator. the system is not as reliable and controlled as the internal regulated Delco SI10 series alternators.
Were it mine, I would use the newer Delco alternator with internal regulation.
The charge light can be used (See diagram) if the resistor and lamp are both good. The connection to terminal 4 of the existing regulator is disconnected and extended as needed to attach to the spade terminal #1 of the Delco. The #2 terminal of the new Delco is connected to the wire now connected to the #3 connection on the old regulator. Both of these can be with 14 gauge wire. The heavy wire on the original alternator's BAT terminal is connected to the new alternator's Bat terminal. The original regulator can be removed.
It is pretty simple. Jim
  Upload Photo  Select Gallery Photo  Attach Serial No List
