Re: More MD questions
Posted by Haas on July 10, 2001 at 14:41:52 from (129.37.117.146):
In Reply to: More MD questions posted by Brad Whitty on July 10, 2001 at 10:22:11:
Don't understand your comment about the side pulley?? Are you talking about the belt pulley?? It is entirely separate from the Lift all. You do not need to split the tractor to remove the lift all. There is a cover plate under the tractor just behind it that is held by two bolts. Take that cover off and you can see the shaft coupling that drives the lift all pump. To get the lift all out, take out the three half inch pipes, one on the right and two on the left. They just screw out. Remove the operating lever by undoing the screw that holds in. Then you can remove the four bolts on the bottom that hold it up in there. BE CAREFUL!!! It weighs over 100 pounds. You need help to get it out, or replace the 3/8 inch bolts one at a time with 3/8 threaded rod and nuts and then jack it down with the nuts. You have to position the shaft coupling so the "cross" will slide out of the slots. The set up you have sounds like home made. For it to work, you have to lock the lift all lever in the lift position, then fluid flows through the spool valves mounted on the pedastal and returns to the fill port of the lift all. When you work the spool valves, fluid under pressure will be directed to your implement cylinder. If you do not have the lift all control rod in the lift position (all the way back) you will get nothing.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
