Re: Re: 12V conversion with a magneto
Posted by Andy Martin on August 12, 2001 at 07:25:01 from (63.27.16.88):
In Reply to: Re: 12V conversion with a magneto posted by Ron/Pa. on August 12, 2001 at 05:01:03:
When they say the ignition is separate from the rest of the electrical system, you need to recognize that the wire from the magneto is used to kill the tractor. When you turn the switch off, the switch grounds that wire. When you turn the switch on, the switch "un-grounds" that wire. It never has external electrical power to it.
Lots of old magneto tractors have no wire running from the magneto. They work just fine, but you have to slow them down and us ethe choke to kill the engine.
Converting to negative ground helps prevent an accident should anyone attemp to jump start the tractor, or use it to jump start another vehicle without identifying that it is a positive ground.
Post A Followup
: Re: Re: Re: 12V conversion with a magneto
Today's Featured Article - Ford Super Dexta - by Anthony West. The rusty blue tractor caught my eye as my truck zipped by the farm implement business. It looked so fornlorn amongst the lineup of newer equipment. But it was just the right size for my small farm. I stopped in and asked the proprietor for further information. "It's a 64 Ford Super Dexta", he said. "It's a tough little tractor, although it's a hard starter being a diesel and all." He did manage to get it running, compliments of a can of ether. Once started it putted along pretty good. It ... [Read Article]
